When I print to my Canon LBP2900, Ubuntu shows printing completes, but nothing is really printed.
K7AAY
  • 17,705
4 steps are needed:
1) install the drivers
2) Register the printer (PPD)
3) Register the printer in the ccpd daemon setup file
4) Start ccpd daemon
STEP ONE go here http://support-asia.canon-asia.com/contents/ASIA/EN/0100459601.html and download and save what will be linux-capt-drv-v271-uken.tar.gz
open a terminal; copy each command below; line by line; paste it into the terminal; hit ENTER key after each paste;
cd Downloads
tar -zxvf linux-capt-drv-v271-uken.tar.gz
cd linux-capt-drv-v271-uken/64-bit_Driver/Debian
sudo dpkg -i cndrvcups-common_3.21-1_amd64.deb
sudo dpkg -i cndrvcups-capt_2.71-1_amd64.deb
Now we assume you have only one usb printer; and that is the LBP2900;
STEP TWO
sudo /usr/sbin/lpadmin -p LBP2900 -P /usr/share/cups/model/CNCUPSLBP2900CAPTK.ppd -v ccp://localhost:59787 -E
STEP THREE
sudo /usr/sbin/ccpdadmin -p LBP2900 -o /dev/usb/lp0
STEP FOUR
sudo /etc/init.d/ccpd start
then you should be able to open LibreOffice or some programme and see if you can print
pdc
  • 1,132
