ubuntu 18.04 Just installed, running
apt update
returns, after a lot of time, a lot of issues like
Err:4 http://gb.archive.ubuntu.com/ubuntu bionic InRelease
Connection failed [IP: 91.189.88.162 80] 0% [Waiting for headers]
The problem is, i can't install apache
apt install apache2
returns
Reading package lists... Done
Building dependency tree
apache2 : Depends: apache2-bin (= 2.4.29-1ubuntu4.1) but it is not going to be installed
Depends: apache2-utils (= 2.4.29-1ubuntu4.1)
Tried just everything, searching, but I think that this happens because of apt update which can't finish up in a correct way, and also the link http://us.archive.ubuntu.com/ubuntu is not working for me, can it be from internet provider, does this link opening from you guys, and if yes, so what can i do for this?
Simple apt update makes a lot of trouble, which i never met before, stupid situation
- I tried to change
/etc/resolv.confwith
#nameserver 8.8.8.8 #nameserver 8.8.4.4 nameserver 192.168.8.1
no result.
2.
apt clean
apt autoclean
3. removed the source.list rm /etc/apt/sources.list and lost a lot of data, which was inside, from user answer #Anwar which i am afraid made it worse.
- Tried to change
http://us.archive.tohttp://old-releases.no result
Any idea? This little problem makes impossible to use ubuntu.
Thanks a lot!!!
