-2
when I put the usb drive that contain XP files it appears to me a black window with this
                 gnu grub version 2.02 beta2-36 ubuntu 3.12
minimal BASH- like line editing is supported for the first word, tab lists possible
command completion. Anywhere else TAB lists possible device or file completions
grub>
Note:I am new with linux!
mook765
  • 18,644
Files aren't enough to create a bootable USB device. When you put Linux or any other OS onto a USB disk for installation, you are really putting three things onto the disk. The three parts are the MBR (master boot record), the first thing your computer reads and executes when you boot the USB device, the file system (where the files are stored, written, and read), and the files to install the OS (i386, docs, etc. for XP). Don't just copy the files over to the USB. Use Rufus ~ https://rufus.akeo.ie/ to create bootable USB drives.
This black screen appears because you deleted Ubuntu without deleting grub, so when you restart your PC, it hangs on grub since there is no Operating System (OS) to start.
To fix this :
First, you should use a tool or a software to make a USB drive bootable (I suggest Universal USB installer if you are running on Windows or GParted if you are using Linux).
Then, plug your USB drive to the PC and restart it. Then, before the grub appears, press the button that opens the BIOS settings. After that, go to boot section and put the USB drive in the top of boot list. Then, save and exit.
After restarting this time, it should boot on the USB drive and you can install Windows XP on your PC.
singrium
  • 7,320
