I wanted to modify several layouts to make them phonetic (асдф and ასდფ where asdf are), and add some missing letters in the Georgian keyboard.
I checked the following threads, among others:
http://xahlee.info/linux/linux_keyboard_tools.html
https://www.charvolant.org/doug/xkb/html/index.html
I modified and saved the corresponding files in /usr/share/X11/xkb/symbols/ but even after restarting the layouts worked just the same. I checked the files and they had changed.
Say I changed
key <AC05> {[0x010010d2,G,0x010010f9]};
to
key <AC05> {[0x010010d2,Georgian_ghan,0x010010f9]};
but shift+g still produced G. Also, the third and fourth positions (for altgr and altgr+shift) never work at all.
Then I found these threads:
Why aren't my modifications to xkb working?
https://ubuntuforums.org/showthread.php?t=1589744
us keyboard not working in 14.04 after removing *.xkm files from /var/lib/xkb
And went to /var/lib/xkb only to find it was empty except for a readmefile, that I moved to another location to check if it'd work, to no avail.
I've also tried to make new layouts from scratch, copying the code form other files, but it doesn't work.
I'm at a loss, I don't know what else to do to be able to have the layouts I need. I've had linux and lubuntu for only a few months and this issue has consumed already lots of hours of my time only to somehow being able to change a couple of keys of the Russian keyboard.
Any help would be much appreciated.
hurixi
XKB does not recognize all character names, and probably it doesn't understand Georgian_ghan. Try 0x010010e6 instead.
(ღ is also available with the Georgian layout through Shift+R.)
