I found Keyboards Shortcuts but it only accepts combos with 3 buttons (Ctrl+Shift+?), even for those where originally only 2 buttons are used (like original combo Super + Space).
So I can't change Super+Space to Ctrl+Shift or Alt+Shift.
Can anyone explain why this is?
graham
  • 13,061
DDR
  • 273
Install Tweaks (package: gnome-tweaks). Then use Tweaks to set an alternative layout switcher.
The full sequence of actions would be: Ctrl+Alt+T
 sudo apt-get install gnome-tweak-tool
 gnome-tweaks
then in the window Keyboard&Mouse -> Additional Layout Options -> Switching to another layout
DDR
  • 273
1- Open Settings>Devices>Keyboard
2- you will find the shortcut set to super + space, change it to Ctrl+Shift or whatever you want. Or you can add the shortcut that you want.
singrium
  • 7,320
