why do we use shebang in the beginning of a shell script file. does the script will run without it.
I tried running it without shebang in shell script but it didn't run.
When a file script starts with the shebang directive
#!langpath args
and has execution permissions set, Unix will "replace it" by
exec langpath args path-to-the-script.
This ways, typically:
  • langpath defines the language to be used, ans should be the path of an executable interpreter of the (programming) language (ex: '/usr/bin/python')
  • the language should accept a script file as an argument
  • the language should ignore the #!... directive as a comment
Different shells support different features. To give effective advice, ShellCheck needs to know which shell your script is going to run on. You will get a different numbers of warnings about different things depending on your target shell.
ShellCheck normally determines your target shell from the shebang (having e.g. #!/bin/sh as the first line). The shell can also be specified from the CLI with -s, e.g. shellcheck -s sh file.
If you don't specify shebang nor -s, ShellCheck gives this message and proceeds with some default (bash).
Note that this error can not be ignored with a directive. It is not a suggestion to improve your script, but a warning that ShellCheck lacks information it needs to be helpful.
delfiler
  • 237
