I have dual booted(win 7 + ubuntu 14.04) last year. But few days ago I can't boot to any OS, so I decided to install new Ubuntu 18.04 only. So, when I made a partition table and proceed to install, this lines are prompted. I'm not quite familiar with these.
The partition table format in use on your disks normally requires you to create a separate partition for boot loader code. This partition should be marked for use as “EFI boot partition” and should be at least 35 MB in size. Note that this is not the same as a partition mounted on /boot.
If you do not go back to the partitioning menu and correct this error, boot loader installation may fail later, although it may still be possible to install the boot loader to a partition.
Sajjad
  • 51
I was using Windows 10 (EFI boot) and installed Ubuntu 18.04 (Legacy boot) on second partition of the same drive. Ubuntu installer prompted the same message you are asking about. I've proceeded regardless the warning and both Windows and Ubuntu works just fine. (Note that swap partition is no longer needed in case of Ubuntu 18.04 if you are creating partitions manually.)
