i have ubuntu 16.4 as Host with IP 192.168.56.1 and Windows 7 as guest inside Virtualbox have IP 192.168.5.101 and the adapter mode is host-only , the host and guest can contact each other on Ping command . the Host can telnet and Curl the guest but the reverse is not working . the error message tell me that the connection failed on port 23 , i have test new port the same issue . i have disabled the firewall on Host and Guest also the AV on Guest . i have enabled the telnet on the Host and Guest . i know that the telnet is not secure but fro some reason i want do that .
Asked
Active
Viewed 1,290 times
