lokesh@lokesh-pc:~$ python3 --version
Python 3.6.5
lokesh@lokesh-pc:~$ pip3 --version
bash: pip3: command not found
lokesh@lokesh-pc:~$ sudo apt-get install python3-pip
[sudo] password for lokesh:
Reading package lists... Done
Building dependency tree
 python3-pip : Depends: python-pip-whl (= 9.0.1-2) but 9.0.1-2.3 is to be installed
               Recommends: python3-dev (>= 3.2) but it is not going to be installed
               Recommends: python3-wheel but it is not going to be installed
karel
  • 122,292
  • 133
  • 301
  • 332
  1. Make sure you remove all non-default sources from sources.lst
  2. Check and remove all software which was installed earlier but has potentially left some packages
  3. apt update
  4. Install
sssnek
