So, I'm new to linux I'm using Lubuntu 17.10. When I try to install a package either in a terminal or software centre. I tried everything even re-installing and that didn't help!
When I try to install through terminal I get this message:
E: Unable to locate package (package name).
In the software centre I try to install a program but nothing happens :/
Can anyone help me? Thanks!
This error shows up when your Sources.list doesn't have the information about the package you're trying to install.
If you're too new and don't know what is sources.list.
Apt uses a file that lists the 'sources' from which packages can be obtained. This file is located at /etc/apt/sources.list.
Possible steps to fix your issue :
  1. Make sure that the package you want to install actually exists or not.
  2. Run sudo apt-update to update sources.list, then try installing package again.
  3. If even after step 2 your problem isn't solving, generate a sources.list using this online website : https://repogen.simplylinux.ch/
You can also try add repositories (main, universe, restricted, multiverse) manually by using the following commands
sudo add-apt-repository main
sudo add-apt-repository universe
sudo add-apt-repository restricted
sudo add-apt-repository multiverse
Vishesh Gautam
  • 768
  • 14
