I tried to install Ubuntu on my WindowsXP machine as a second OS.
I do not get the option "Install Ubuntu alongside them" when I go through the guided installation process from the Live-CD.
Any idea or help on what I could do?
Further information:
I have three primary partitions:
  • (without title) 78MB FAT
  • Recovery (D:) 10 GB NTFS
  • (C:) 136.47 GB NTFS
  • And one extended partition (as a logical drive): - Mediadirect 2.5 GB FAT 32
There is no unpartitioned disk space left
My drive is a basic drive and I ran chkdsk (no errors found) but the problem persists
Tobias
  • 31
Note that you already have 4 partitions which is the maximum amount possible in the MBR partition table, so Ubuntu can't create another primary partition.
It would be able to create another logical partition inside your extended partition, but the latter is too small to install Ubuntu there.
So Ubuntu unstaller is literally out of options here :) You need to help it by shrinking your C: drive and then moving/resizing your extended partition to make it a bit larger. In the process you can even create an ext4 logical partition for your Ubuntu manually.
As I remember Ubuntu requires somewhere between 6 and 7 Gb of disk space to install.
Sergey
  • 44,353
