18
I was using ubuntu16.04 upgraded to ubuntu 18.04. followed some tutorial to remove npm, but now stuck. I have:
~$ npm list -g
bash: /usr/bin/npm: No such file or directory
and:
     sudo apt-get install npm
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: npm : Depends: nodejs but it is not going to be installed Depends: node-abbrev (>= 1.0.4) but it is not going to be installed Depends: node-ansi (>= 0.3.0-2) but it is not going to be installed Depends: node-ansi-color-table but it is not going to be installed Depends: node-archy but it is not going to be installed Depends: node-block-stream but it is not going to be installed Depends: node-fstream (>= 0.1.22) but it is not going to be installed Depends: node-fstream-ignore but it is not going to be installed Depends: node-github-url-from-git but it is not going to be installed Depends: node-glob (>= 3.1.21) but it is not going to be installed Depends: node-graceful-fs (>= 2.0.0) but it is not going to be installed Depends: node-inherits but it is not going to be installed Depends: node-ini (>= 1.1.0) but it is not going to be installed Depends: node-lockfile but it is not going to be installed Depends: node-lru-cache (>= 2.3.0) but it is not going to be installed Depends: node-minimatch (>= 0.2.11) but it is not going to be installed Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed Depends: node-gyp (>= 0.10.9) but it is not going to be installed Depends: node-nopt (>= 3.0.1) but it is not going to be installed Depends: node-npmlog but it is not going to be installed Depends: node-once but it is not going to be installed Depends: node-osenv but it is not going to be installed Depends: node-read but it is not going to be installed Depends: node-read-package-json (>= 1.1.0) but it is not going to be installed Depends: node-request (>= 2.25.0) but it is not going to be installed Depends: node-retry but it is not going to be installed Depends: node-rimraf (>= 2.2.2) but it is not going to be installed Depends: node-semver (>= 2.1.0) but it is not going to be installed Depends: node-sha but it is not going to be installed Depends: node-slide but it is not going to be installed Depends: node-tar (>= 0.1.18) but it is not going to be installed Depends: node-underscore but it is not going to be installed Depends: node-which but it is not going to be installed E: Unable to correct problems, you have held broken packages.
dlin
  • 3,900
Aipo
  • 375
Follow up: Latest instructions to install nodejs on Ubuntu. Official Nodejs docs
Original answer is below.
I was having the same problem. After a lot of search online I managed to find a solution.
The following is what solved it for me:
Remove old nodejs installation and update packages.
sudo apt-get remove nodejs npm
sudo apt-get update
sudo apt-get upgrade
For 8.x node installations:
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
For 12.x node installations:
curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
Install:
sudo apt-get install -y nodejs
Test the installation:
~$ nodejs -v
v8.11.3 // <- node 8.x
v12.13.1  // <- node 12.x
~$ npm -v 5.6.0 // <- node 8.x 6.12.1 // <- node 12.x
azbatuk
  • 446
