I'm trying to install GTK library in ubuntu 16.04 LTS but I'm getting error saying E: Unable to correct problems, you have held broken packages.
nikhil@nikhil-desktop:~$ sudo apt-get install libgtk-3-dev
Reading package lists... Done
Building dependency tree
libgtk-3-dev : Depends: libgtk-3-0 (= 3.18.9-1ubuntu3) but 3.20.8-1ubuntu0~ppa1 is to be installed
Depends: gir1.2-gtk-3.0 (= 3.18.9-1ubuntu3) but 3.20.8-1ubuntu0~ppa1 is to be installed
Depends: libgdk-pixbuf2.0-dev (>= 2.30.0) but it is not going to be installed
Depends: libpango1.0-dev (>= 1.37.3) but it is not going to be installed
Depends: libatk-bridge2.0-dev but it is not going to be installed
Depends: libepoxy-dev (>= 1.0) but it is not going to be installed
Depends: libxcursor-dev but it is not going to be installed
Depends: libegl1-mesa-dev but it is not going to be installed
Depends: libwayland-dev (>= 1.5.91) but it is not going to be installed
Depends: libmirclient-dev (>= 0.13.3) but it is not going to be installed
Depends: nettle-dev but it is not going to be installed
How can I fix this issue, I'm trying to install opencv with this package library, how can I install it without getting any errors, I'm following instructions from PYimage search.
