I have scoured the web, including veracrypt official forums for this and nothing. It's almost like support does not exist for this issue.
When I go to mount the partition, it spits out this error: mount: /media/veracrypt1: can't read superblock on /dev/mapper/veracrypt1.
Now, in the Veracrypt GUI application, it shows it mount for a brief few seconds before spitting the error then it disappears from the list.
I own all the hardware, and use Ubuntu MATE 18.04 with no issues. I have 1 other partition not encrypted on this drive in question and it mounts perfectly fine and can be utilized. My other veracrypt partitions mounted on other drives at the same time did not experience this error as I can still mount them and utilize the drives.
I'm pretty decent with the terminal and other issues but this one baffles me.
Here's what I was doing:
1) Copying large wordlist files from this partition to my laptop.
2) The laptop completely froze.
3) I waited for 3 hours and it was still frozen.
4) No apparent I/O to the disks.
5) Held the power button down.
6) Rebooted fine.
After the reboot, I proceed to mount and it started spitting that error.
Now, I have other important files on there I'd like to get back if possible.
What I've tried:
1) Mounting via terminal but I could still use support on this
2) Force mounting and trying to recover the superblock but I can't because it will not mount the partition long enough to capture anything.
3) The GUI mounting options yet nothing worked.
4) Checked passphrases numerous times.
5) Rebooted numerous times, checked all connections.
The only relevant post is Can't read superblock with veracrypt and the OP avoided posting the solution after greedily asking for information that he resolved himself. I, however, will continue trying to make it work with diminishing returns and if I somehow figure this out, will post the solution.
Any help would be greatly appreciated.
----EDIT----
The answer supplied by "Frustrated Crypter" below is correct. It works. I managed to experience this issue except slightly different with the same storage media and it worked!!! I was able to recover the data EXACTLY as "Frustrated Crypter" described.
When Frustrated Crypter mentioned mapping it without mounting, there is a button called "Options" that expands the popup that asks for the password of the drive/partition/file you are trying to mount. In that expanded options, there is a checkbox to select that prevents it from mounting. After that, I simply right clicked on the mapped but not mounted drive/partition/file and chose Repair.. Solved all my issues right then and there.
"Frustrated Crypter", whoever you are, I'd like to buy you a beer(I'm not even lying). Message me somehow on here so I can properly thank you for your input on this matter when no one else had a guide or walk through.
