I cannot establish a connection to the openvpn server anymore.
grep VPN /var/sys/log
Gives me this output:
Starting OpenVPN connection to server...
Failed to start OpenVPN connection to server.
Stopped OpenVPN connection to server.
The openvpn log in /var/log/openvpn.log doesnt seem to exist.
EDIT: I'm guessing I messed the server config up somehow? I get these logs from:
grep ovpn /var/sys/log
May 16 03:06:50 xxx ovpn-server[23659]: Options error: --dh fails with 'dh2048.pem': No such file or directory (errno=2)
May 16 03:06:45 xxx ovpn-server[23654]: Options error: --cert fails with 'server.crt': No such file or directory (errno=2)
May 16 03:06:50 xxx ovpn-server[23659]: WARNING: cannot stat file 'server.key': No such file or directory (errno=2)
May 16 03:06:50 xxx ovpn-server[23659]: Options error: --key fails with 'server.key': No such file or directory (errno=2)
May 16 03:06:50 xxx ovpn-server[23659]: Options error: Please correct these errors.
Any ideas?
Morkohl
  • 121
Permission chmod issues maybe?
When I upgraded to 18.04, my vpn client stopped working but I just installed network-manager-openvpn and network-manager-openvpn-gnome via terminal and it allows me to just pick openvpn config files and it connects from there.
Maybe this will be a possible workaround for you if it is not permissions related.
EDIT: I looked up what you said and came to the openvpn forums with an apparent work around. https://forums.openvpn.net/viewtopic.php?t=23979
Apparently my user certificates wont load because they are secured by md5 and openssl considers these too weak.
Logs:
Any suggestions? Downgrade to a different OpenSSL version?
Wed May 16 14:05:49 2018 OpenSSL: error:140AB18E:SSL routines:SSL_CTX_use_certificate:ca md too weak
Morkohl
  • 121
My issue was that 18.04 introduced netplan and netplan/networkmanager agree to not manage each others interfaces. Until the latest upgrade, my configurations had been in place, but something had gotten overwritten.
I ended up removing the configuration from netplan and update the networkmanager config to name all the interfaces.
I also found the instructions for not using netplan below.
Ubuntu 17.10 disable netplan
sudo apt install ifupdown
sudo apt purge netplan
My /etc/network/interfaces looks like this:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
I also had changed the name of my Broadcom NetXtreme Gigabit network card as it was non-standard from the old name to eth0
/etc/udev/rules.d/70-persistent-net.rules
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<<your macid here>>", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="eth0"
instructions
sudo service restart networking
sudo service restart network-manager
abu_bua
  • 11,313
