I assume the below command does the following (please correct me if I am wrong):
I want to remove the package nginx and the related configuration files. I also want to remove any related package dependencies (that are not used by any other package on the system)
sudo apt autoremove --purge nginx
Question
Does it also remove the configuration files for the related package(s) (dependencies) that are removed from the system?
dohjon
  • 85
Short Answer : Yes, but not every file related to package is deleted as purge doesn't remove data stored by packages inside the home directory or other special directories.
By Standard definition of Purge:-
Purge - Purge is identical to remove except that packages are removed and purged. Purge meaning that any configuration files are deleted too.
Paul
  • 4,606
Vishesh Gautam
  • 768
  • 14
