Yesterday I've let windows 10 update but on restart grub was showing "unknown filesystem". After trying all solutions I've found on the web for that issue, I've used Ubuntu Live to fix that and now only Windows boot shows.
Having experienced similar problems before, I used Ubuntu live usb once again and for hours tried desperately to restore Ubuntu. I've tried all solutions I've found on the internet and moved no further...
Here are the coordinates of the issue:
fdisk -l
 Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors Units:
 sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512
 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
 Disklabel type: dos Disk identifier: 0x76936d13
 Device     Boot     Start       End   Sectors  Size Id Type /dev/sda1
 *         2048    206847    204800  100M  7 HPFS/NTFS/exFAT /dev/sda2          206848 385979729 385772882  184G  7 HPFS/NTFS/exFAT /dev/sda3
 385980416 386936831    956416  467M 27 Hidden NTFS WinRE /dev/sda4
 386940926 468860927  81920002 39.1G  5 Extended /dev/sda5
 460462080 468860927   8398848    4G 82 Linux swap / Solaris
grub-install /dev/sda4
 Installing for i386-pc platform. grub-install: error: failed to get
 canonical path of `/cow'.
mount /dev/sda4 /mnt
 mount: /mnt: wrong fs type, bad option, bad superblock on /dev/sda4,
 missing codepage or helper program, or other error.
testdisk
 Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63
      Partition               Start        End    Size in sectors
 * HPFS - NTFS              0  32 33    12 223 19     204800
 P HPFS - NTFS             12 223 20 24026  43 17  385773568
 P HPFS - NTFS     24026  43 18 24085 179 30     956416
 L Linux                24085 211 63 28662  79 25   73521152
 L Linux Swap           28662 111 58 29185  61 60    8398848
If I'm trying to set Linux partition as primary bootable it says "Structure bad".
How can I make my ubuntu work once again or at least recover my projects from that linux partition?
stumblebee
  • 4,379
