I have just came across something that is really bothering me. Autocompletion on ubuntu works like a charm but when I login as root, e.g. su I get tab autocompletion only sometimes.
Why does it work like that? Can one change that?
Check your /root/.bashrc file for these lines
if [ -f /etc/bash_completion ]; then
. /etc/bash_completion
fi
If they do not exist add them to the end of the file using your favorite text editor.
Please note, that the autocompletion will start working just after logging out and back again!
You haven't mentioned which Ubuntu version you use.
Check if you have the bash-completion package installed:
sudo apt-get install bash-completion
Mine works if I login using: sudo -i
For Ubuntu 13.10, check /etc/bash.bashrc for
# enable bash completion in interactive shells
if ! shopt -oq posix; then
if [ -f /usr/share/bash-completion/bash_completion ]; then
. /usr/share/bash-completion/bash_completion
elif [ -f /etc/bash_completion ]; then
fi
fi
They might be commented. Un-commenting them works.
Found that this worked (similar to the answers above but with a twist)
The file that needs to be edited (at least in my case with 12.04) was /root/.bashrc. This makes sense in my case, given that my regular user was autocompleting just fine but my root wasn't.
Anyway in said file I found all the necessary code but it was commented out:
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
#if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
#. /etc/bash_completion
#fi
Just un-commented it:
fi
Saved, and it worked just fine.
Hope this helps someone.
In Linux Mint 18 (based on Xenial), you have to edit your bashrc :
sudo nano /etc/bash.bashrc
and comment out (remove the # in front of each line) this section :
fi
fi
That’s all.
