I am playing around with networking component of latest Ubuntu. I faced the above issue when I tried to manage networking devices with NM.
The command line output is
root@sankar:~# nmcli d s
DEVICE  TYPE      STATE      CONNECTION
eth0    ethernet  unmanaged  --
eth1    ethernet  unmanaged  --
eth2    ethernet  unmanaged  --
lo      loopback  unmanaged  --
I tried couple of solutions(comment #36 and #30) given in https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/1638842.
Any help is highly appreciated
Dan
  • 14,180
I had this happen with an installation of Ubuntu Server 18.04 (Which uses netplan) and then adding a desktop window manager GUI (in our case, xubuntu-core^).
No Manner of re-configuring or nmcli would make these devices managed.
The solutions you tried were close, we found that if you follow the answer located here: Ethernet device not managed and note that the location of the 10-globally-managed-devices.conf is in the folder /user/lib/ you will be able to active those network devices by blanking the 10-globally-managed-devices.conf file with:
sudo mv /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf  /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf_orig
and
sudo touch /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf
And restarting network-manager or rebooting.
G Koe
  • 286
