32
I have tried to download a file from https://logz.io/sample-data.
curl -O https://logz.io/sample-data
However, it just returns an empty file named sample-data.
In contrast to curl, however, wget works well returning a file containing proper contents.
wget https://logz.io/sample-data
What have I missed with curl?
heemayl
  • 93,925
user3523935
  • 455
You've missed to follow redirections with curl as the URL endpoint is redirected (301) to another endpoint (https://s3.amazonaws.com/logzio-elk/apache-daily-access.log); sending a request with HEAD method (-I) to the specified URL:
% curl -LI https://logz.io/sample-data
HTTP/1.1 301 Moved Permanently
Location: https://s3.amazonaws.com/logzio-elk/apache-daily-access.log
HTTP/1.1 200 OK
Server: AmazonS3
As curl does not follow HTTP redirections by default, you need to tell curl to do so using the -L/--location option:
curl -LO https://logz.io/sample-data
As wget follows redirections by default, you're getting to the eventual URL with wget as-is.
heemayl
  • 93,925
