165
How can I download files (that are listed in a text file) using wget or some other automatic way?
Sample file list:
www.example.com/1.pdf
www.example.com/2.pdf
www.example.com/3.pdf
rav_kr
  • 124
Sourav
  • 2,325
8 Answers8
279
wget has a built-in flag for this: wget -i your_list, where your_list is a file containing URL's delimited by linebreaks. You can find this kind of thing by reading man wget
aureianimus
  • 3,586
91
Get them in parallel with
cat urlfile | parallel --gnu "wget {}"
By default it will run as many processes as you have cores, you can probably ramp this up another 10x if you really want to pull them down quickly by adding "-j 20" after parallel.
meawoppl
  • 1,054
14
parallel has a built-in flag --arg-file (-a) that will use an input-file as the source, so you can avoid cat |. You can use
parallel --gnu -a urlfile wget
Or simply parallel --gnu wget < urlfile
yxogenium
  • 141
10
xargs -i wget 'http://{}'  < your_list
awk '{print "http://" $0;}' list.txt | xargs -l1 wget
where list.txt is your list file
cbix
  • 187
I saw Florian Diesch's answer.
I got it to work by including the parameter bqc in the command.
xargs -i wget -bqc 'http://{}' < download.txt
All downloads started in parallel in the background.
  • -b: Background. Go to background immediately after start
  • -q: Quiet. Turn off wget's output
  • -c: Continue. Continue getting a partially-downloaded file
muru
  • 207,228
Link file links.txt
Command for down load all links file
cat links.txt | wget -i
Kulfy
  • 18,154
I just tested this:
xargs -a download_file -L1 wget
It works for me. Links inside the txt file must be in separate lines.
Kulfy
  • 18,154
