Have a Asus laptop GL552/ ubuntu 18.04 and a 950gtx. How do i install nvidia driver to recovry my graphic card ? I had already downloaded a file "NVIDIA-Linux-x86_64-390.48.run".
Using the *.run installer makes your updates depend on manual operations.
I suggest you instead have a look in
System Settings > Software and Updates > / Additional Drivers \
Selecting:
(*) Using NVIDIA Binary Driver - ...
... in here, will have you get updates automatically, without manual intervention.
The updates might not happen for every bleeding edge driver release, but instead you have a stable hassle free time using the computer.
If you REALLY wish to install the *.run driver; make sure you put it in a place you can find it when using the recovery console; e.g. put it in the root home directory:
sudo -i
cd; mv /the/path/<...>/*.run .
Then reboot into the recovery console and run the installer from there
bash NVIDIA<...>.run
Due to the way this installs; you may, at a later point in time, encounter problems in case of kernel & gui driver (e.g. xorg) updates.
If that happens, the "easy" fix is to use the recovery console to
--uninstall the driver and then immediately
--install it again,
after having made sure you booted with the NEW software active (i.e. using the new kernel).
Caveat: That strategy worked well on 14.04, haven't tried it since...
Note:
bash NVIDIA<...>.run --help | less
will tell you a lot.
Hannu
  • 6,605
  • 28
  • 45
