Windows won't boot after installing Ubuntu from a usb stick. I tried updating grub:
$ sudo update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-4.15.0-20-generic
Found initrd image: /boot/initrd.img-4.15.0-20-generic
Found Windows Boot Manager on /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for EFI firmware configuration
done
It did't help.I checked my partitions and there is a microsoft reserved partition at /dev/sda3 and flags msftres.
I also tried updating grub from startup up window from advanced options under ubuntu header.
While installing i made three separate partitions, and before anything I had my window partition shrunk, as was required.
codedump
  • 126
sarp
Does grub bootloader work fine? If so you can just choose to boot to Windows from grub menu. Otherwise will you please post more information in this?
codedump
  • 126
