I'm getting the error below when I am trying to use Grub Customizer on Ubuntu
grub-customizer: error while loading shared libraries: libatkmm-1.6.so.1: cannot open shared object file: No such file or directory
I am not sure where exactly what has gone wrong as I only installed Ubuntu today.
- Legovil
Legovil
I was getting the same error when launching grub-customizer in ubuntu 18.04, what I did was just find the path of the missing library:
    $ sudo find / -name "libatkmm-1.6.so.1"
    /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libatkmm-1.6.so.1
after that, I included the lib directory to the file that configures the libs environment variable:
    $ sudo su
    # echo "/snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu" >> /etc/ld.so.conf.d/x86_64-linux-gnu.conf
    # ldconfig
and it worked.
OR you can create symbolic links into an already default lib path:
    sudo ln -s /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libatkmm-1.6.so.1.1.0 /usr/lib/x86_64-linux-gnu/libatkmm-1.6.so.1
    sudo ln -s /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libpangomm-1.4.so.1.0.30 /usr/lib/x86_64-linux-gnu/libpangomm-1.4.so.1
    sudo ln -s /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libglibmm-2.4.so.1.3.0 /usr/lib/x86_64-linux-gnu/libglibmm-2.4.so.1
    sudo ln -s /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libcairomm-1.0.so.1.4.0 /usr/lib/x86_64-linux-gnu/libcairomm-1.0.so.1
    sudo ln -s /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libsigc-2.0.so.0.0.0 /usr/lib/x86_64-linux-gnu/libsigc-2.0.so.0
    sudo ln -s /snap/gnome-system-monitor/36/usr/lib/x86_64-linux-gnu/libgiomm-2.4.so.1.3.0 /usr/lib/x86_64-linux-gnu/libgiomm-2.4.so.1
Mikochien
