when I run import numypy in python 3 , the following appears : ModuleNotFoundError: No module named 'numpy'
So you might say try pip3 install numpy But it is already installed which is confirmed when I run pip3 install numpy it shows:
Requirement already satisfied: numpy in /home/shreyash/.local/lib/python3.5/site-packages (1.14.3)
I did try python3 -m pip install numpy but it says : No module named pip
additinal info: i use pip version 10.0.1 check the terminal screenshot :-(
related question : Can't uninstall Python 3.6
I'm unable to make my code run in neither of python2.7 , python3.5 , python 3.6.
numpy works fine with version 2.7 but then it encounters the same problem for using matplotlib. I'm fine with whatever python version so long as I'm able to run my code. I would prefer version 3.x though.
