I just fresh installed Ubuntu 18.04 and tried to get the LAMP stack. During install, no pop-up screen for MySQL server configuration, during installation of the OS. I tried to login using root w/out password (default is no password), permission denied. Run mysql_secure_installation, set a password for root user, then I tried to login using the password I set, it still says permission denied even I typed the correct password. I tried to start the service manually, it turns out to time out. Purged mysql-server and change to mariadb-server, same thing. Is it a bug in MySQL server in 18.04? I have used MySQL in 17.10, no issues.
Excerpt of journalctl -xe:
-- Unit mariadb.service has begun starting up.
May 13 05:55:09 v1 mysqld[4863]: 2018-05-13  5:55:09 140117780589696 [Note] /usr/sbin/mysqld (mysqld 10.1.29-MariaDB-6) starting as process 4863 ...
May 13 05:55:09 v1 audit[4863]: AVC apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld" name="run/systemd/notify" pid=48
May 13 05:55:09 v1 kernel: audit: type=1400 audit(1526190909.418:36): apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld
May 13 05:56:39 v1 systemd[1]: mariadb.service: Start operation timed out. Terminating.
May 13 05:56:39 v1 audit[4863]: AVC apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld" name="run/systemd/notify" pid=48
May 13 05:56:39 v1 kernel: audit: type=1400 audit(1526190999.051:37): apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld
May 13 05:56:41 v1 audit[4863]: AVC apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld" name="run/systemd/notify" pid=48
May 13 05:56:41 v1 kernel: audit: type=1400 audit(1526191001.179:38): apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld
May 13 05:56:41 v1 kernel: audit: type=1400 audit(1526191001.179:39): apparmor="DENIED" operation="sendmsg" info="Failed name lookup - disconnected path" error=-13 profile="/usr/sbin/mysqld
May 13 05:56:41 v1 systemd[1]: mariadb.service: Failed with result 'timeout'.
May 13 05:56:41 v1 systemd[1]: Failed to start MariaDB database server.
-- Subject: Unit mariadb.service has failed
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- Unit mariadb.service has failed.
Expected output during LAMP stack installation in Ubuntu server
