How do I keep a volume mounted when I boot into Ubuntu 18.04
It disappears on every boot.
Thank you
Add an entry to your systems filesystem table (/etc/fstab) is the easiest method in my opinion.
For ext4 you can add the following
UUID=xxxxxxxx    /mount-dir    ext4    defaults    0    0
where the xxxxxxxx is replaced by your UUID (unique ID for the device/partition) and /mount-dir is replaced by the directory you want it mounted to. (space(s) or tabs can be used between parameters)
To find out the UUID, use sudo blkid
guiverc
  • 33,561
