My PC freezes before the login screen (Ubuntu logo); if I select RECOVERY MODE and resume boot everything goes well. I suspect a problem with the graphics driver.
karel
  • 122,292
  • 133
  • 301
  • 332
Marcelo4k
  • 191
Finally I was able to solve the issue by uncommenting the line #WaylandEnable=false in /etc/gdm3/custom.conf
Zanna
  • 72,312
Marcelo4k
  • 191
Perhaps i can supplement the answer to @Vishesh Gautam and @Marcelo4k:
In the ArchWiki page on GNOME desktop environment, it is stated that "the default display is Wayland instead of Xorg." Hence, there maybe problem if the default display server is Xorg. It is noted that Ubuntu 18.04 default display server is Xorg. This explains the issue if /etc/gdm3/custom.conf has wayland display server enabled.
@Marcelo4k has successfully troubleshoot the problem by uncommenting the line #WaylandEnable=false, so Wayland display server is disabled and Xorg will be the active display server. This is noted in Fedora documentation as the first step to disable Wayland to run Gnome on Xorg. It further recommended to add a new line under [daemon] section:
DefaultSession=gnome-xorg.desktop
The above recommendation is valid if the result of gdm3 is active (running) using systemctl status:
systemctl status gdm3
However if gdm3 is disabled and lightdm is enabled perhaps due to upgrade from Ubuntu 16.04 to Ubuntu 18.04. Then lightdm maybe active (running) instead.
So if lightdm is inactive, do as what @Vishesh Gautam has suggested by running sudo start lightdm or running as below to start light display manager:
systemctl start lightdm
However these applies only to Gnome desktop environment. If you have other desktop environments matched with other display managers, you have to consult relevant documentations to your respective desktop environment and display managers. Again, ArchWiki provide a good introduction to Display manager and they give a relevant list on how to match which desktop environment to which display manager.
Hope this helps.
This answer is applicable for lightdm.
Most probably the login display manager is not starting, try starting the Lightdm manually (if you haven't changed it, i.e Default) from TTY by the following command : sudo start lightdm
A display manager presents the user with a login screen. A session starts when a user successfully enters a valid combination of username and password.
PS : If you don't know, you can access TTY by pressing CTRL+ALT+F1/2/3/4 at the freeze point you're referring to and then login with username and password.
Vishesh Gautam
  • 768
  • 14
-1
A combination of the advice here solved the same issue for me on Ubuntu 19.10.
When the system started and hung with the mouse pointer at the bottom right of the screen, I was able to move it but there was no login window.
I pressed Ctrl+Alt+F2 to start a console session in TTY2, logged in and opened the file /etc/gdm3/custom.conf. There I uncommented the line #WaylandEnable=false (by deleting the # at the beginning of the line)
I then typed reboot and tadaaaaaa!
Zanna
  • 72,312
