As the title suggests I'm a new to linux and I'm having some trouble setting up it up. I have a DELL inspiron n5110 with an nVidia 525m and i7-2630QM. Well after a bit of reading and confusing myself I followed instructions in this tutorial, which seemed to work. The battery usage dropped from ~2000 to ~1600. Thou it's not as much as I'd like to. So I tried the Intel tweaks.
After applying the Intel tweaks it didn't take any effect, I think I did something wrong. Thou I'm not sure. But the comments stated that most people saw a drop to ~1000. I wanted to try just disabled the card on boot with the instructions here: http://github.com/Bumblebee-Project/bbswitch, but I can't open /etc/modules trough the terminal. It says "Permission denied" or "Command not found" if I use sudo /etc/modules. I'm not sure what other info do you need to be able to make any sense of this. So just ask and tell you what I can. I'd need to achieve a much lower usage one way or another, because I need to the laptop in class.
Lekensteyn
  • 178,446
Bumblebee installation instructions can also be found in Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu?
It includes bbswitch by default, so you do not have to get the code from the Git repository nor edit /etc/modules (it's a file, not a command/program!) because the card is disabled when Bumblebee starts. Keep in mind that the power usage depends on the machine your have. For example, I have a GT425M GPU with an i5-460M CPU. That'll use way less power than an i7 processor. To improve battery life:
  • Lower the brightness level of the screen
  • Disable wireless if you are only taking notes or reading PDFs in class and do not need to use Internet
  • Disable the webcam (Fn + ??) and other unnecessary peripherals like Bluetooth
  • Apply the Intel module options as mentioned in Battery life decreased after upgrade to 11.04
Lekensteyn
  • 178,446
