When I switch on my laptop, it boots and goes into blinking stage. Keyboard and mouse work.
After do a force shutdown using power button and boot again, this problem is gone and it boots normally.
I did boot-repair and it didn't help me either. Or is this a common bug in 18.04
Any suggestions about installing ubuntu-desktop again as suggested here?
I did a version upgrade from Ubuntu 16.04 to 18.04. My Laptop is hp with AMD-A6 and Readon-R4 graphics.
Sachith Muhandiram
  • 215
  • 20
If you happen to have an AMD graphics card, try the solution proposed in this answer:
I solved it myself by using amdgpu.dc=0 as a boot parameter.
To do this, edit the file /etc/default/grub, for example using
sudoedit /etc/default/grub
Find the line beginning GRUB_CMDLINE_LINUX_DEFAULT and add the text amdgpu.dc=0 between the double quotes (""). Leave any other parameters as they are. For example, you may end up with a line like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash amdgpu.dc=0"
Save the file and exit, and then run
sudo update-grub
to write the configuration, and reboot.
Sean
  • 163
While the Ubuntu screen was flickering I hit cntl-alt-del and it rebooted and when to the boot screen to select an OS. I selected Ubuntu and it booted without problems.
The easiest way is to:
  1. Boot your Linux in ("Recovery Mode")
  2. After going into Recovery mode, select "Update GRUB"
  3. Press ENTER on "UPDATE GRUB"
  4. Reboot
Worked for me, I had a blinking screen on my Ubuntu 18.04 with Intel graphics, but as long as you are on X drivers (by default and recommended strongly - by my opinion) you'll be fine, if not please let me know there is a way around. But, as I said, these 3-4 steps will resolve your issue with blinking splash/ boot screen when "Ubuntu is loading".
Thank you.
