I upgraded to 18.04 (actually it said partial upgrade) and now have no sound, I tried to install pulseaudio as it seems to be missing but I ge the message below.
dave@Dave-PC:~$ sudo apt install pulseaudio
[sudo] password for dave:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 pulseaudio : Depends: libpulse0 (= 1:10.0-2ubuntu3.1) but 1:11.1-1ubuntu7 is to be installed
dave@Dave-PC:~$
How do I fix this?
Elder Geek
  • 36,752
The error speaks itself, the missing dependency / library is libpulse which can be found in libpulse-dev package.
First purge it by (So that obsolete installation is deleted) :
sudo apt purge libpulse-dev
And then install it :
sudo apt install libpulse-dev
And then try installing pulseaudio.
Vishesh Gautam
  • 768
  • 14
