I have recently installed Ubuntu 18.04 (Not upgrade, a clean install). In Ubuntu 18.04, the rendering LaTeX function in Inkscape is not working. Following is the error output:
*** WARNING - the DELAYBIND command has been deprecated, and will be
removed in the next version. For now you can restore
the behaviour by using -dREALLYDEALYBIND but if you
require continued use of this command you should contact
the Ghostscript developers. Commercial customers of
Artifex should email their support contact, free users
are encouraged to talk to us on the #ghostscript IRC
channel on irc.freenode.net.
Unrecoverable error: undefined in DELAYBIND
PostScript/PDF Interpreter finished. Return status 65280 executed command : /usr/bin/gs -q -dDELAYBIND -dWRITESYSTEMDICT -dNODISPLAY -dNOEPS "/tmp/psin5eNNQ0"
The interpreter seems to have failed, cannot proceed !
Traceback (most recent call last):
File "eqtexsvg.py", line 160, in <module>
e.affect()
File "/usr/share/inkscape/extensions/inkex.py", line 283, in affect
self.effect()
File "eqtexsvg.py", line 154, in effect
svg_open(self, svg_file)
File "eqtexsvg.py", line 81, in svg_open
doc = inkex.etree.parse(filename)
File "src/lxml/etree.pyx", line 3426, in lxml.etree.parse
File "src/lxml/parser.pxi", line 1839, in lxml.etree._parseDocument
File "src/lxml/parser.pxi", line 1865, in lxml.etree._parseDocumentFromURL
File "src/lxml/parser.pxi", line 1769, in lxml.etree._parseDocFromFile
File "src/lxml/parser.pxi", line 1162, in lxml.etree._BaseParser._parseDocFromFile
File "src/lxml/parser.pxi", line 600, in lxml.etree._ParserContext._handleParseResultDoc
File "src/lxml/parser.pxi", line 710, in lxml.etree._handleParseResult
File "src/lxml/parser.pxi", line 639, in lxml.etree._raiseParseError
File "/tmp/inkscape-Y11679/eq.svg", line 1
lxml.etree.XMLSyntaxError: Document is empty, line 1, column 1
From the google search, what I have found that the problem is arising because of the ghostscript. The Render>LaTeX extension actually calls pstoedit which in terns calls ghostscript using DELAYBIND flag to convert from LaTeX to SVG. But in the newer version of ghostscript the flag DELAYBIND has been deprecated. The solution is to downgrade ghostscript to or below 9.20 version. The following are the methods that I have tried to downgrade ghostscript without any success.
Downgrading ghostscript from apt or aptitute
I have tried to downgrade the ghostrict using the following command.
sudo aptitude install ghostscript=9.18~dfsg~0-0ubuntu2
Or by using
sudo apt install ghostscript=9.18~dfsg~0-0ubuntu2
I am getting the following output
Unable to find a version "9.18~dfsg~0-0ubuntu2" for the package "ghostscript"
or
E: Version '9.18~dfsg~0-0ubuntu2' for 'ghostscript' was not found
I have tried some other version, like 9.20 of ghost script. Nothing worked.
Installing from ghostscript website:
I have downloaded the ghostscript from the ghostscript website, and installed using the following command
sudo ./configure
sudo make
sudo make install
It seems the installation is done, but if I am running the command
ghostscript --version
It is showing the version as 9.22.
All the online solution that I am able to find is pointing towards the downgrading the ghostscript. But I don't know how to do it in Ubuntu 18.04.
Any solution?
