I'm looking for specific instructions for this, noting that How do I install a .tar.gz (or .tar.bz2) file? can give general guidance.
In other words, what to do with VMware-converter-6.2.0-7348398.odp.tgz (*)?
The answer to this might be plain obvious, but since a quick search did not give any helpful results and the guide on vmware.com is only for the Windows-based installation, I figured it would be worthwhile asking here.
(*) downloaded (for free, after registering) from here on my.vmware.com. See also this unanswered question on communities.vmware.com.
/tmp/VMware-converter-6.2.0-7348398.odp$ ls
bash-4.1 iconv-1.9.2 reiserfsprogs-3.6.19
build_ttylinux.sh iptables-1.4.9.1 SYSTEMS.txt
busybox-1.11.1 libiconv-1.9.2 tar-1.28
busybox-1.18.4 libmspack-0.0.20040308alpha test
e2fsprogs-1.40.11 libparted-3.1 ttylinux-12.6
e2fsprogs-1.41.12 log4cpp-1.0 udev-163
efibootmgr-0.5.4 lvm2-2.02.95 util-linux-ng-2.18
extract_helper.sh module-init-tools-3.12 vmware-sysinfo-1.0
glib-2.24.2-1 net-tools-1.60 xfsprogs-3.2.2
glibc-2.12.1 package_helper.sh
grub-0.97-75 procps-3.2.7-1
content of SYSTEMS.txt:
The following systems are used when building this VMware disclosure. The domain "example.org" is used in this document to define systems. Please adjust this domain and hostnames to match your environment.
"rhel-7.3-x32" This is a Red Hat EL 7.3 system. The ISO images for this install are available at http://redhat.lsu.edu/dist/7.3/iso/ This system should be configured with at least 32 Gb of disk space to accomodate build. A kickstart file to configure this system is is available in the directory config/rhel-7.3-x32.cfg along with a floppy image file (rhel-7.3-x32.flp) containing this ks.cfg file. The 7.3 system does not support kickstart files over http, the floppy image should be used instead. The system should be configure using the boot prompt command
linux ks=floppy after attaching the floppy image to the diskette device. The kickstart file includes a "%post" section which * Configures the system to automount the shared file server used to host the VMware Toolchain disclosure. Please adjust the hostname for this server in the kickstart file. * Creates the user "vmware" with a home directory of "/usr/vmware". The directories under this home directory are used when building disclosed packages. The passwords defined by the kickstart file for the "vmware" user is "welcome". No internet based updated are applied to this system. The "as installed" system is used when building package. For your reference, the ISO images used by VMware for this system were cb91810ce8173039fed24420407e4c59 valhalla-i386-disc1.iso ec1b813d32ffdc8edc2be261735d17de valhalla-i386-disc2.iso 5dc81ce523cfddf99b4d4d63e91bcaa7 valhalla-i386-disc3.iso NOTE: A similiarly configured system is used when building the VMware Toolchain disclosure. However, that system is not configured to automount the shared file server: the %post sections differ."centos-4.8-x32" This is a CentOS 4.8 32-bit system. This system should be configured with at least 16 Gb of disk space to accomodate builds. A kickstart file to configure this system is is available in the file "config/centos-4.8-x32-ks.cfg". The file should be stored on a web server, e.g., "ns.example.org" and the system should be configure using the boot prompt command
linux ks=http://ns.example.org/centos-4.8-x32-ks.cfg The kickstart file includes a "%post" section which * Configures the system to automount the shared file server used to host the VMware Toolchain disclosure. Please adjust the hostname for this server in the kickstart file. * Creates the user "vmware" with a home directory of "/usr/vmware". The directories under this home directory are used when building disclosed packages. The passwords defined by the kickstart file for both "root" and "vmware" are both "welcome". No internet based updated are applied to this system. The "as installed" system is used when building package. For your reference, the ISO image used by VMware for this system was (MD5 checksum): f663dfc0a0ee610d23c223468004c745 CentOS-4.8-i386-binDVD.iso"centos-5.3-x32" This is a CentOS 5.3 32-bit system. This system should be configured with at least 16 Gb of disk space to accomodate builds. A kickstart file to configure this system is is available in the file "config/centos-5.3-x32-ks.cfg". The file should be stored on a web server, e.g., "ns.example.org" and the system should be configure using the boot prompt command
linux ks=http://ns.example.org/centos-5.3-x32-ks.cfg The kickstart file includes a "%post" section which * Configures the system to automount the shared file server used to host the VMware Toolchain disclosure. Please adjust the hostname for this server in the kickstart file. * Creates the user "vmware" with a home directory of "/usr/vmware". The directories under this home directory are used when building disclosed packages. * Disables services not required when building disclosures. The passwords defined by the kickstart file for both "root" and "vmware" are both "welcome". No internet based updated are applied to this system. The "as installed" system is used when building packages. For your reference, the ISO image used by VMware for this system was (MD5 checksum): 997638cd72a559e38f9fd1955a368231 CentOS-5.3-i386-bin-DVD.iso"centos-5.3-x64" This is a CentOS 5.3 64-bit system. This system should be configured with at least 16 Gb of disk space to accomodate builds. A kickstart file to configure this system is is available in the file "config/centos-5.3-x64-ks.cfg". The file should be stored on a web server, e.g., "ns.example.org" and the system should be configure using the boot prompt command
linux ks=http://ns.example.org/centos-5.3-x64-ks.cfg The kickstart file includes a "%post" section which * Configures the system to automount the shared file server used to host the VMware Toolchain disclosure. Please adjust the hostname for this server in the kickstart file. * Creates the user "vmware" with a home directory of "/usr/vmware". The directories under this home directory are used when building disclosed packages. * Disables services not required when building disclosures. The passwords defined by the kickstart file for both "root" and "vmware" are both "welcome". No internet based updated are applied to this system. The "as installed" system is used when building packages. For your reference, the ISO image used by VMware for this system was (MD5 checksum): 6d4fd59688ed8644514010316d6a5698 CentOS-5.3-x86_64-bin-DVD.iso"freebsd-6.3-x32" This is a FreeBSD 6.3 32-bit system. This system should be configured with at least 16 Gb of disk space to accomodate builds. A kickstart file is not available for this system. Please install using the
Standard Begin a standard installation (recommended) installation option. When the "Choose Distributions" menu is displayed please select the distributions X-Developer Kern-Developer X-User The install should be performed against CD/DVD media. For your reference, the ISO images used by VMware for this system were (MD5 checksum): cdb0dfa4b2db3e4c9cc19138f4fb2ada 6.3-RELEASE-i386-disc1.iso e73a3d9cf5f3bfbf07384ef0a93ae5d5 6.3-RELEASE-i386-disc2.iso 123840107a5578ce22875c440d41f453 6.3-RELEASE-i386-disc3.iso"freebsd-6.3-x64" This is a FreeBSD 6.3 64-bit system. This system should be configured with at least 16 Gb of disk space to accomodate builds. A kickstart file is not available for this system. Please install using the
Standard Begin a standard installation (recommended) installation option. When the "Choose Distributions" menu is displayed please select the distributions X-Developer Kern-Developer X-User The install should be performed against CD/DVD media. For your reference, the ISO images used by VMware for this system were (MD5 checksum): a8d41ea26769919db6c0c672fa8f8c4f 6.3-RELEASE-amd64-disc1.iso a243076fb99b011d9b0771a6f7f9a977 6.3-RELEASE-amd64-disc2.iso 92831414b34b4b06cfb7140ddfe69cfe 6.3-RELEASE-amd64-disc3.iso"windows-xp-x64" This is a Windows XP Professional 64-bit. Please perform the following steps:
1. Install Windows XP Professional 64-bit. VMware uses Microsoft 32 bit compilers on a 64 bit system to build the 32 bit Toolchain. 2. Install Visual studio 2008 Professional Edition. * Install everything under Visual C++ Language Tools including X64 Compilers & Tools * Apply the SP1 patch from http://www.microsoft.com/downloads/details.aspx?FamilyId=FBEE1648-7106-44A7-9649-6D9F6D58056E&displaylang=en to your visual studio installation. 3. Copy the following to c:\toolchain\win32\bin Copy fromdos.exe and todos.exe - http://tofrodos.sourceforge.net/download/tfd1712a.zip Copy usr/local/wbin/* from UnxUtils - http://sourceforge.net/projects/unxutils/files/unxutils/current/UnxUtils.zip/download Install Cygwin and then copy "sh.exe", and "cp.exe", and "tar.exe" (and various cygwin dlls required to run them) from the Cygwin installation. At the time of publishing, the commands to do this are: $ cd \Toolchain\win32\bin $ copy \cygwin\bin\sh.exe sh.exe $ copy \cygwin\bin\cp.exe cp.exe $ copy \cygwin\bin\tar.exe tar.exe $ copy \cygwin\bin\cygwin1.dll cygwin1.dll $ copy \cygwin\bin\cygintl-8.dll cygintl-8.dll $ copy \cygwin\bin\cygiconv-2.dll cygiconv-2.dll $ copy \cygwin\bin\cygreadline7.dll cygreadline7.dll $ copy \cygwin\bin\cygncursesw-10.dll cygncursesw-10.dll $ copy \cygwin\bin\cyggcc_s-1.dll cyggcc_s-1.dll $ copy \cygwin\bin\cygattr-1.dll cygattr-1.dll 4. Copy over the Windows toolchain binaries for win32 and win64 from the shared file system to the below folders: C:\toolchain\win32 C:\toolchain\win64 5. Please use Visual Studio 2008 x64 Cross Tools Command Prompt to build 64-bit binaries and use Visual Studio 2008 Command Prompt to build 32-bit binaries. 6. Add C:\toolchain\win32\bin to PATH $ set PATH=C:\toolchain\win32\bin;%PATH% NOTE: A similiarly configured system is used when building the VMware Toolchain disclosure.
$ sudo find . -print | grep -i 'install'
[sudo] password for _______________________:
./xfsprogs-3.2.2/INSTALL.txt
./e2fsprogs-1.40.11/INSTALL.txt
./busybox-1.18.4/INSTALL.txt
./grub-0.97-75/INSTALL.txt
./iconv-1.9.2/INSTALL.txt
./busybox-1.11.1/INSTALL.txt
./libiconv-1.9.2/INSTALL.txt
./e2fsprogs-1.41.12/INSTALL.txt
./log4cpp-1.0/INSTALL.txt
./glib-2.24.2-1/INSTALL.txt
./tar-1.28/INSTALL.txt
./udev-163/INSTALL.txt
./iptables-1.4.9.1/INSTALL.txt
./util-linux-ng-2.18/INSTALL.txt
./reiserfsprogs-3.6.19/INSTALL.txt
./ttylinux-12.6/INSTALL.txt
./procps-3.2.7-1/INSTALL.txt
./glibc-2.12.1/INSTALL.txt
./bash-4.1/INSTALL.txt
./libmspack-0.0.20040308alpha/INSTALL.txt
./net-tools-1.60/INSTALL.txt
./net-tools-1.60/net-tools-1.60-installlib.patch
./lvm2-2.02.95/INSTALL.txt
./efibootmgr-0.5.4/INSTALL.txt
./vmware-sysinfo-1.0/INSTALL.txt
./module-init-tools-3.12/INSTALL.txt
./test/sysinfo-install.sh
./test/helper-install.sh
./libparted-3.1/INSTALL.txt
