My Dell Optiplex which was running Ubuntu 17.10 on a small HDD died this week, so I replaced the whole machine and installed Ubuntu 17.10 on a new SSD drive, thinking it would improve performance. I followed the default partition option with an EFI partition on the SSD. The problem is that several aspects of the system seem slower. Unfortunately I can't quantify it but I get a sense of laggy-ness and generally poor responsiveness (mouse movement, scrolling text files, program load time, etc -- but not only interface responsiveness).
In short, should I simply return to my previous setup? I assumed there would be some benefits running the OS on the SSD. Is it worth the hassle trying to configure things correctly? Sorry if this question is very vague.
Keith
Mouse movement, scrolling text has nothing to do with the speed of your hard disk. That is all -memory- based.
That is a question only you can answer.
In my opinion: yes, if only for understanding your system better.
In regards to slow responses from mouse and scrolling:
  • Open top in a terminal and have it visible. When the mouse lags or scrolling lags check what the processes are that eat up your resources.
  • Do a memory scan to check if the memory is faulty.
  • Also make a note of all your hardware and see if you can identify any problems there. If, as an example, you have 1Gb in memory you will see performance increase adding 3 or 7 more.
Rinzwind
  • 309,379
