Ubuntu can't detect my GPU. Jockey shows no drivers whatsoever and I can't even install the nvidia drivers through sudo apt-get install nvidia-current. That's what I get :
Error! Bad return status for module build on kernel: 3.2.0-030200-generic (x86_64)
Consult the make.log in the build directory
/var/lib/dkms/nvidia-current/195.36.24/build/ for more information.
dpkg: error processing nvidia-current (--configure):
subprocess installed post-installation script returned error exit status 10
dpkg: dependency problems prevent configuration of nvidia-current-dev:
nvidia-current-dev depends on nvidia-current (>= 195.36.24); however:
Package nvidia-current is not configured yet.
dpkg: error processing nvidia-current-dev (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-glx-185:
nvidia-glx-185 depends on nvidia-current; however:
dpkg: error processing nvidia-glx-185 (--configure):
Processing triggers for python-gmenu ...
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because the error message indicates its a followup error from a previous failure. Rebuilding /usr/share/applications/desktop.en_US.utf8.cache...
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.2.0-030200-generic
Processing triggers for python-support ...
nvidia-current
nvidia-current-dev
nvidia-glx-185
I'm using Ubuntu 10.04 and the 3.2.0 kernel. any help ?
