I get the following when trying to install Docker on Ubuntu 16.04:
michael@michael-VirtualBox:~$ sudo apt-get update
Err:8 https://download.docker.com/linux/ubuntu \ Release
  404  Not Found [IP: 13.32.250.25 443]
Reading package lists... Done
E: The repository 'https://download.docker.com/linux/ubuntu \ Release' does not have a Release file.
N: Updating from such a repository can't be done securely and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Can someone help me fix this issue?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Your software source is likely wrong. If you use the command listed here the command should look like:
add-apt-repository deb [arch=amd64] https://download.docker.com/linux/ubuntu xenial stable
This is also more or less the new line that is added to /etc/apt/sources.lst
xenoid
  • 5,759
Secure source did not work for me; if you are having the same problem as myself you might want to try with the following repository link.
add following to your /etc/apt/sources.list file:
deb [arch=amd64] http://download.docker.com/linux/ubuntu xenial stable
David Foerster
  • 36,890
  • 56
  • 97
  • 151
uspinar
  • 101
