when i enter the command:
sudo apt-get install libboost-all-dev libx11-dev libx11-dev:i386 libxtst-dev libconfig++-dev build-essential qt5-default
i get this:
Reading package lists... Done
Building dependency tree
build-essential is already the newest version (12.4ubuntu1).
libx11-dev is already the newest version (2:1.6.4-3).
libboost-all-dev : Depends: libboost-iostreams-dev but it is not going to be installed
Depends: libboost-mpi-dev but it is not going to be installed
Depends: libboost-mpi-python-dev but it is not going to be installed
Depends: libboost-regex-dev but it is not going to be installed
libxtst-dev : Depends: libxext-dev but it is not going to be installed
Depends: libxi-dev but it is not going to be installed
qt5-default : Depends: qtbase5-dev but it is not going to be installed
how do i fix this?
RESULT OF APT-CACHE:https://pastebin.com/Ya6ycT84
edit:all of the packages have missing dependencies
