In Arduino IDE the serial port is greyed out and COM 1 i shown in the window There is no way to communicate trough serial connection. Dont know if this is a Arduino Bugg or a bugg in Bionic Beaver. The application worked in 17.10 Artfull.
This bugg is reported and a fix is awaiting an upload in debian
May 9:
Fixed the NullPointerException with Java 10 caused by the null java.ext.dirs system property (Closes: #896929)
Its not a Arduino only problem but affect serial connections in general.
Tested Pronterface and there is no serial connection to 3D printer.
bolean
  • 291
5 Answers5
The serial communication/uploader problem was fixed for me by following the instructions for installing Oracle java 8 from this posting:
https://linuxconfig.org/how-to-install-java-on-ubuntu-18-04-bionic-beaver-linux
on a newly installed Ubuntu 18.04 LTS system. After installing Oracle java 8:
  • $ sudo add-apt-repository ppa:webupd8team/java
  • $ sudo apt update
  • $ sudo apt install oracle-java8-set-default
the Arduino IDE worked properly.
You should give your user permissions to write to serial port with
sudo usermod -a -G dialout $USER
Also see "How to install latest Arduino IDE?".
It seems that it is real bug, I also get on clean Ubuntu 18.04 LTS:
$ arduino
java.lang.NullPointerException thrown while loading gnu.io.RXTXCommDriver
$ dpkg -S `which arduino`
arduino: /usr/bin/arduino
$ dpkg -l arduino | tail -n1
ii  arduino        2:1.0.5+dfsg2-4.1 all          AVR development board IDE and built-in librarie
so I reported bug 1770604 to launchpad with linked Debian Bugs:
N0rbert
  • 103,263
I was facing the same problem. I installed version Arduino IDE 1.9.0 beta and I no longer see that error.
Try it using,
and, don't forget to change permission, example COM1 as ttyUSB0 :
ls -l /dev/tty*
sudo chmod a+rw /dev/ttyUSB0
Download the latest Arduino IDE from arduino.cc, extract the archive and make install.sh executable with chmod +x install.sh or through the Permissions tab of the file's properties. After this you can run sudo ./install.sh - from a terminal that has the extracted folder as its current path - to install the Arduino IDE. This should fix your problem.
Thanks to CharlieS for the suggestion by comment.
魔大农
  • 153
