I have windows and linux dual boot, each of them in different physical disk. As i no longer need to boot to windows, how can i add that disk to linux root partition? Can a root partition uses two disks? Thanks.
Asked
Active
Viewed 1,793 times
You cannot "share" the root partition over two disks. You will need to mount the second disk somewhere.
Idea 1 - Use it as a drive from file manager
Format the disk using your favorite formatting utility and mount it in your file manager. This should be the easiest option.
Idea 2 - Use it for your /home folder
You could use this other disk as your /home by following the tutorial here: How to Move Home Directory to New Partition or Disk in Linux
Joshua Besneatte
- 4,861
