I have Ubuntu 18.04 LTS installed.
I installed Arduino IDE v1.8.5 as a snap with
snap install arduino-mhall119
I have added my user to dial-out group and rebooted:
sudo usermod -a -G dialout $USER
$ groups
username adm dialout cdrom sudo dip plugdev lpadmin sambashare
I connected my Arduino Nano to the laptop, it is detected on port /dev/ttyUSB0 (ch341-uart).
$ ls /dev/ttyUSB0 -al
crw-rw---- 1 root dialout 188, 0 авг 13 11:59 /dev/ttyUSB0
I tried to upload the simpliest Blink sketch and get the following errors in the terminal:
$ arduino-mhall119.arduino
avrdude: ser_open(): can't open device "/dev/ttyUSB0": Permission denied
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.**
Also I have installed arduino 1.8.5 with umake - it can access serial port in usual way.
Note: we already have similar question here, but the solution was to use package from umake, not fix for the Snap.
So my question is: How to make Arduino (Snap) access serial port /dev/ttyUSB0 (or /dev/ttyACM0)?
Update: connecting serial-port to the snap fails with the following message
$ snap connect arduino-mhall119:serial-port
error: snap "core" has no "serial-port" interface slots
Current interfaces are:
$ snap interfaces | grep arduino
:home                            arduino-mhall119,gedit,organize-my-files,vlc
:network                         arduino-mhall119,gedit,organize-my-files,pulsemixer,vlc
:unity7                          arduino-mhall119,gedit,organize-my-files,vlc
:x11                             arduino-mhall119,organize-my-files,pulsemixer,vlc
-                                arduino-mhall119:serial-port
Changing permissions of serial port to 777 with sudo chmod 777 /dev/ttyUSB0 does not help.
The following do not work too (because of syntax errors):
$ sudo snap connect arduino-mhall119:arduino
error: snap "arduino-mhall119" has no plug named "arduino"
$ snap connect arduino-mhall119:/dev/ttyUSB0
error: snap "arduino-mhall119" has no plug named "/dev/ttyUSB0"
error: cannot resolve connection, plug snap name is empty
Information about YAML-manifest:
$ ls -l /snap/arduino-mhall119/current/meta/snap.yaml
-rw-r--r-- 1 root root 353 июл 28 00:20 /snap/arduino-mhall119/current/meta/snap.yaml
$ cat /snap/arduino-mhall119/current/meta/snap.yaml |grep -A 12 slots
$ cat /snap/arduino-mhall119/current/meta/snap.yaml |grep -A 5 plug
    plugs:
    - x11
    - unity7
    - home
    - network
    - serial-port
N0rbert
  • 103,263
2020 update
The arduino-mhall119 snap is outdated and should not be used anymore. Use the arduino snap instead.
See this answer for up to date info on how to get serial working with the arduino snap.
Old instructions
Install the snap in classic mode to allow access to ports
$ snap install arduino-mhall119 --classic
It's that simple. You should now have access to your serial ports! Happy Hacking!
Note: info below are needed for old Arduino 1.6.10.
Some interesting links that helped find the answer
Auto connected serial port interface
Lundamar says: Until the serial-port gadget/interface is improved to give access to all system serial devices you can get your snap working by simply installing it non-confined like so:
$ snap install tio --classic
It’s better than nothing but it surely would be best to run it confined with allowed access to serial tty devices.
Interfaces - serial-port
Interfaces reference:
serial-port
Can access serial ports. This is restricted because it provides privileged access to configure serial port hardware. Note that the slot is meant to be implemented by a gadget snap (this is not provided by the core snap).
Gadget providing serial-port slot
The arduino-mhall119 snap is outdated and should not be used anymore. Use the arduino snap instead.:
Using that snap, the only thing you need to do is add your own user to the dailout group:
After this, reboot your device and open Arduino IDE.
N0rbert
  • 103,263
The solution of Joshua did not work for me anymore since I got the error:
Warning: flag --classic ignored for strictly confined snap arduino-mhall119
However, when using devmode instead it worked fine:
$ snap install arduino-mhall119 --devmode
Not sure if there are any further consequences with devmode though..
Sebastian
  • 433
