Can someone tell me what terminal command the alias ll is for? All I can find online is many people saying that it is an alias for ls -l or ls -la or ls -ltr. But that's simply wrong. The result looks different. Is there any way to locate ll and look at its syntax?
You can use the alias or type commands to check what a specific alias means:
$ alias ll
alias ll='ls -alF'
$ type ll
ll is aliased to `ls -alF'
Note however that aliases might use other aliases, so you might have to check it recursively, e.g. in the case of ll, you should also check the ls command it calls:
$ alias ls
alias ls='ls --color=auto'
$ type ls
ls is aliased to `ls --color=auto'
So ll actually means:
ls --color=auto -alF
- 110,243
ll is an alias defined in your ~/.bashrc, provided you didn't change it it's ls -alF:
$ grep ll= <~/.bashrc
alias ll='ls -alF'
These three options are:
- -a, --all – do not ignore entries starting with .
- -l – use a long listing format
- -F, --classify – append indicator (one of */=>@|) to entries
As
$ grep ls= <~/.bashrc
shows, ls itself is again an alias for ls --color=auto:
With
--color=auto,lsemits color codes only when standard output is connected to a terminal. TheLS_COLORSenvironment variable can change the settings. Use thedircolorscommand to set it.
- 40,956
You can look in your ~/.bashrc (or some file where your aliases are) or you can write some of these commands in your shell:
command -v ll # "command" is a shell built-in that display information about
# the command. Use the built-in "help command" to see the
# options.
type -p ll # "type" is another built-in that display information about how the
# command would be interpreted
grep -r "alias ll=" ~ # and don't worry about de .file that contains your
# alias. This command search recursively under each
# folder of your home. So it's something rude.
find ~ -maxdepth 1 -type f | xargs grep "alias ll" # Just look in
# the files (not folders) in your home folder
But why use find without the -name ".*" ? Cause you can put this in your .bashrc
source bash_hacks # where the file bash_hacks, in your home directory can
# contain the alias ll='ls -la etc etc'.
Since "ll" it's an alias, it's not necesary that have just one meaning (ll='ls -alF --color'), you can alias your "ll" like another comand like, i don't know, "rm". I think it's more a convention (product of common uses).
But "ll" could be a program stored in any folder of your PATH. For example, if you have a folder named "bin" in your home, make a "ll" script that contains something like
#!/bin/bash
ls -lhar
But, what if your PATH have been altered to add another folder that contains the new "ll" command? For more interesting information, you can consult the following link to a related question.
- 201
There is no need to parse ~/.bashrc or any other script. You can check your current values of all aliases typing alias command in terminal. It will bring all defined aliases with their definitions onto your screen.
- 113
