I moved from 17.04 to 18.04 but there is a lot of changes in windows switching and workspaces. On 17.04 I had to use windows+S key to open all workspaces and then navigate via arrow keys to select. Plus each window was visible in its workplace, it wasn't accessible from other workspaces.
If I have two windows of terminal or code editor, I was able to open them via alt+tab long press and then I had to select the window between. Now it’s like press alt+tab, then press down key for selection between same application windows.
It’s extremely annoying, please suggest a solution.
Melebius
  • 11,750
Comrade
  • 215
It is possible like
Alt+Tab and then Alt+^ (or Alt+´ in US-layout) to switch between windows in same application.
Info found here: https://help.ubuntu.com/stable/ubuntu-help/shell-windows-switching.html
pomsky
  • 70,557
Andi S.
  • 209
