This bug has tormented me for a full week now, and I still had not managed to fix it after countless installs on 3 different systems. In the end I followed the tip from Terrance with some tweaks and it seemed to work for me. I decided to clean up my approach and provide it here as a full answer.
The problem seems to be with the binary nvidia binary driver version 390 which is default.
To fix the problem, simply install the next version 396. You can do this in Ubuntu 18.04LTS (Bionic Beaver) follow the steps below:
Run the following command to install a repository dedicated to the latest graphics driver versions:
sudo apt-add-repository ppa:graphics-drivers/ppa
You have to press ENTER at the prompt.
Then run the following command to update your repo locally with new ppa:
sudo apt update
Finally run the following command to install version 396 of the graphics driver:
sudo apt install nvidia-driver-396
At this stage you may be good to go, and simply go to the step with the reboot below. However, I also had to make a small change.
Run the following command to open for editing
sudo nano /usr/share/X11/xorg.conf.d/nvidia-drm-outputclass-ubuntu.conf
In that file, comment out the line that says Option "PrimaryGPU" "yes" and save/close the file with <CTRL + O> and <CTRL + X> keyboard combos.
At this stage you may also be fine, however I needed another tweak before I got it working.
Run the following command to edit your sources file>
sudo nano /etc/apt/sources.list
At the bottom of the file add a line on its own:
deb http://us.archive.ubuntu.com/ubuntu/ bionic-proposed multiverse main universe restricted
Save/close the file with <CTRL + O> and <CTRL + X> keyboard combos.
Run the following command to update your local repo agian after adding the new source. WARNING: This will add proposed versions of software to your system, which may be less stable.
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
Run the following command to install some needed packages that may be missing:
sudo apt install libglvnd0 xserver-xorg-core libgl1-mesa-glx
Once this completes, it is time for a reboot.
After the reboot, you can run the command nvidia-smi to see what was installed:
| NVIDIA-SMI 396.24 Driver Version: 396.24 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 760 Off | 00000000:02:00.0 N/A | N/A |
| 49% 51C P0 N/A / N/A | 262MiB / 1998MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
