After an sudo apt-get upgrade, I get the following error:
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tkinter
Traceback (most recent call last):
  File "/usr/lib/python3.5/tkinter/__init__.py", line 36, in <module>
    import _tkinter
ImportError: No module named '_tkinter'
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "/usr/lib/python3.5/tkinter/__init__.py", line 38, in <module>
    raise ImportError(str(msg) + ', please install the python3-tk package')
ImportError: No module named '_tkinter', please install the python3-tk package
I have python3-tk installed. I already tried purging and installing it. Doesn't change anything. (Interestingly, the /usr/lib/python3.5/tkinter still existed after pruging... and manually removing it did only lead to another error)
How can I fix this problem?
Did not solve the problem:
$ sudo apt-get install tk8.6-dev
$ sudo apt-get install python3-tkinter # does not exist
$ sudo apt-get install python3-tk  # exists and is installed
Comment answers
$ ls -l /usr/lib/python3.5/tkinter
total 372
-rw-r--r-- 1 root root   1791 Nov 28 17:50 colorchooser.py
-rw-r--r-- 1 root root   1412 Nov 28 17:50 commondialog.py
-rw-r--r-- 1 root root   1493 Nov 28 17:50 constants.py
-rw-r--r-- 1 root root   1568 Nov 28 17:50 dialog.py
-rw-r--r-- 1 root root  11488 Nov 28 17:50 dnd.py
-rw-r--r-- 1 root root  14502 Nov 28 17:50 filedialog.py
-rw-r--r-- 1 root root   6581 Nov 28 17:50 font.py
-rw-r--r-- 1 root root 162249 Nov 28 17:50 __init__.py
-rw-r--r-- 1 root root    148 Nov 28 17:50 __main__.py
-rw-r--r-- 1 root root   3701 Nov 28 17:50 messagebox.py
drwxr-xr-x 2 root root   4096 Nov 30 08:12 __pycache__
-rw-r--r-- 1 root root   1814 Nov 28 17:50 scrolledtext.py
-rw-r--r-- 1 root root  11424 Nov 28 17:50 simpledialog.py
-rw-r--r-- 1 root root  77014 Nov 28 17:50 tix.py
-rw-r--r-- 1 root root  55839 Nov 28 17:50 ttk.py
When moving the directory, I get:
$ sudo mv tkinter tkinter-backup
$ python3
>>> import tkinter
ImportError: No module named 'tkinter'
More info
$ which python3
/usr/bin/python3
$ apt list python3
Listing... Done
python3/xenial,now 3.5.1-3 amd64 [installed]
Martin Thoma
  • 20,535
The python3-tk package has support for python versions 3.6 and 3.7, not 3.5, which is your default. Change your default python to a version supported if your work supports that. Otherwise, if you really need version3.5, you will need to track down the support files.
ubfan1
  • 19,049
In my case, I was getting the same error as "ImportError: No module named '_tkinter'" for python3.5 in-spite of doing the following things: - Installing python3-tk and tkinter-dev - Tkinter directory being available in /usr/lib/python3.5.
The observed error was from the following file:
File "/usr/local/lib/python3.5/tkinter/init.py", line 35, in import _tkinter # If this fails your Python may not be configured for Tk
However, when I simply ran the python from /usr/bin like /usr/bin/python3.5 from terminal, it worked for me!
In short, just ensure the python version being run from terminal has the tkinter installed and configured :)
I have Ubuntu16.04 installed on my system which comes with default python2.7 and python3.5
Have you tried import Tkinter (with a capital T) in your python program? That did it for me.
OZ1SEJ
  • 1,323
