Is there a way to list all files that have been downloaded in the past 12 hours (or 10 days, or 2 months) without knowing the exact location?
For example, let's say that the system downloaded automatically 1200 files, which are likely in 1 or 2 folders (same hard drive, SDA1), however in this folder there are already 5000 files.
Is there a way from the command line to find out which files where downloaded eg. today and put their names in a txt file? Note that while the files were being downloaded i was working on other files in the same directory, so I am not interested to find out which file(s) was last modified, but more specifically which files where downloaded today.
I'm not sure if there is a specific code that can be used to view just all the downloaded files, but I hope this helps.
if there is common filename for it, for example, you just downloaded a bunch of .zip
you can always use the grep command
find . -type f -newermt 2018-05-07 | grep '.zip' > filename.txt
or if it is a bunch of .zip and .odt
find . -type f -newermt 2018-05-07 | grep '.zip\|.odt' > filename.txt
EXPLANATION
find . -type f -newermt YYYY-MM-DD = finds all files that is modified that day
grep = used to search text or searches the given file for lines containing a match to the given strings or words.
> filename.txt = lets you save all of the output on a text file
-just make sure you are inside of that directory before using this
