I am using gnome-shell on Ubuntu 11.10. After I installed some of the extensions, whenever it logs in; it would not show the userbar (the one with the clock etc). I tried doing the following:
How to remove and reinstall GNOME 3?
But it just doesn't work. Obviously uninstalling will work, but I would like to be able to use the gnome-shell, and not completely remove it - as soon as I install it again; the same problem persists. The userbar does not show up, I just get the background image, and no GUI at all.
Sty
  • 173
You can also remove extensions by going to .local/share/gnome-shell/extensions and removing what you've installed.
On a somewhat related note, I just got into a situation like yours where the user bar wouldn't show up, but I had NO extensions loaded, and un-installing and reinstalling gnome-shell made no difference.
I actually reinstalled Ubuntu (this being 11.10), but used the option to not format the drive. It completely reinstalled the O/S, reinstalled the packages I'd installed since installation, and left my home directory intact (yes, I did have a backup available, but didn't need to use it). And now gnome-shell works fine.
Anwar
  • 77,855
Open gnome-tweak-tool, or install it first using the command sudo apt-get install gnome-tweak-tool.
Open it and there you can view your extensions and deactivate them to see if that's the problem.
Anwar
  • 77,855
