I can't seem to figure out how to disable the "tap dragging"-feature in Ubuntu 18.04's libinput. By disabling "tap dragging" I mean that I want to disable the dragging-functionality when using tap without actually disabling "Tap-to-click". This way when I want to drag something, I'd have to actually click on the touchpad. While it could be a handy feature for some, I don't really need it and it keeps triggering by accident. If it's any help, I am on Macbook Pro, some late-2013 or early-2014 version.
I've tried to search around for an answer, and checked libinput's manual to figure out the correct configuration. What I found was this:
Option "TappingDrag" "bool"
Enables or disables drag during tapping behavior ("tap-and-drag"). When enabled, a tap followed by a finger held down causes a single button down only, all motions of that finger thus translate into dragging motion. Tap-and-drag requires option Tapping to be enabled.
I tried to set this option in /usr/share/X11/xorg.conf.d/40-libinput.conf:
Section "InputClass"
Identifier "libinput touchpad catchall"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
Option "TappingDrag" "false"
EndSection
Reboot and tap dragging is still there. I also tried to add the same TappingDrag-option to the Touchscreen- and Tablet-sections in the config file with no luck. What am I doing wrong?
I hope someone knows the answer, this is really bugging me. Thanks in advance!
