I get read/write error when trying to create a new partitioning table on a USB drive.
sudo mkfs.ext4 /dev/sdc
mke2fs 1.43.9 (8-Feb-2018)
Warning: could not erase sector 2: Input/output error
Creating filesystem with 31258624 4k blocks and 7815168 inodes
Filesystem UUID: 8eac3af0-c5a7-4f09-ba50-8938c382058e
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000, 7962624, 11239424, 20480000, 23887872
Allocating group tables: done
Warning: could not read block 0: Input/output error
Warning: could not erase sector 0: Input/output error
Writing inode tables: done
Creating journal (131072 blocks): done
Writing superblocks and filesystem accounting information:   0/954
It stalls after that. Any ideas?
I also tried:
sudo dd if=/dev/zero of=/dev/sdc status=progress
dd: writing to '/dev/sdc': Input/output error
1+0 records in
0+0 records out
0 bytes copied, 0.00130756 s, 0.0 kB/s
as well as
sudo e2fsck -f /dev/sdc
e2fsck 1.43.9 (8-Feb-2018)
e2fsck: Input/output error while trying to open /dev/sdc
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
 or
    e2fsck -b 32768 <device>
as well as
sudo mke2fs -n /dev/sdc
Filesystem UUID: ada49f78-45f9-49da-b2ef-d76383582ffd
I tried sudo e2fsck -b xxxx where xxxx is a block listed above but it returns the same output all the time:
 or
I don't need to restore any data from this drive just want to make it usable again. Any hints would be greatly appreciated.
use mkfs to format partitions use fdisk or parted to create partition table and partitions
cmak.fr
  • 8,976
