I had the same problem after running sudo do-release-upgrade -d on a Ubuntu 16.04 cloned partition. The intent was to test for bugs in upgrade to 18.04.1 but the system stalled with message:
To continue please press [ENTER]
Inhibiting until Ctrl+C is pressed...
So I pressed Ctrl+C and it returned to command prompt.
Next I ran:
$ sudo apt update
Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:2 http://ca.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://ca.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:4 http://ca.archive.ubuntu.com/ubuntu bionic-backports InRelease
(appstreamcli:15814): GLib-CRITICAL **: g_strchug: assertion 'string != NULL' failed
(appstreamcli:15814): GLib-CRITICAL **: g_strchomp: assertion 'string != NULL' failed
AppStream cache update completed, but some metadata was ignored due to errors.
Reading package lists... Done
Building dependency tree
1675 packages can be upgraded. Run 'apt list --upgradable' to see them.
Based on comments above plus this answer: Hit Ctrl+c during do-release-upgrade. Did I break it? I used:
sudo sed -i -e 's/bionic/xenial/g' /etc/apt/sources.list
Now sudo apt update completes normally.
Problems with upgrade
Now when I run do-release-upgrade -d and pay close attention I notice these lines in the middle:
Get:57 http://ca.archive.ubuntu.com/ubuntu bionic-backports/universe DEP-11 64x64 Icons [1,789 B]
Fetched 44.8 MB in 6s (4,884 kB/s)
(appstreamcli:30117): GLib-CRITICAL **: g_strchug: assertion 'string != NULL' failed
(appstreamcli:30117): GLib-CRITICAL **: g_strchomp: assertion 'string != NULL' failed
Checking package manager
I abort the upgrade by answering N to prompt.
A quick search leads to this Question & Answer: E: Problem executing scripts APT Update::Post-Invoke-Success error during apt-get update
I can verify the same situation using:
$ sudo apt update
Hit:1 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:2 http://ca.archive.ubuntu.com/ubuntu xenial InRelease
Hit:3 http://ca.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:4 http://ca.archive.ubuntu.com/ubuntu xenial-backports InRelease
All packages are up to date.
The recommended solution in the link is to use:
sudo apt-get purge libappstream3
Running this the meta error is now gone:
$ sudo apt update
Next step will be to run sudo do-release-upgrade -d a third time and cross my fingers.
Misleading message during upgrade
Another user had similar problem: Ubuntu upgrade from 16.04 to 18.04 is taking too long
Turns out the two line message comes out at the same time:
You think the upgrade is inhibited until you press Ctrl+C but what it really means is the upgrade doesn't start until you press Enter.
sigh
