i am following the steps from this link to install couch DB in my system having ubuntu 18.04,but it says that release file is missing. steps work perfectly for my ubuntu 16.04
In https://apache.bintray.com/couchdb-deb/dists/ there is no dist for Ubuntu 18.04 LTS (Bionic Beaver). any help will be appreciated.
xExplorer
  • 121
This doesn't exactly answer your question, but a simple option is to run couchDB in a docker container, and not as an installation. To do this simply install docker (here's a question about how to do that), then once that is up and running run this command:
sudo docker run -d -p 5984:5984 --name couchdb apache/couchdb:1.7.1
and an instance of couchdb will be running in a docker container. Go to http://127.0.0.1:5984/_utils/ to verify that its up.
The couchdb team isn't building a binary package for Ubuntu 18.04 (Bionic Beaver) yet.
You can track the issue on github in order to get notified when the couchdb team makes progress on this:
https://github.com/apache/couchdb/issues/1314
If you have to run 18.04, then the only straightforward option is to build your own package from source. Not a huge deal, but a fair number of dependencies, so not a trivial deal either.
http://docs.couchdb.org/en/2.1.1/install/unix.html#installation-from-source
Update
Support for bionic beaver has been added to the build process: https://github.com/apache/couchdb/pull/1347
Docs aren't updated yet, but you should be able to use bionic in place of {distribution} (see the docs) and be all set.
http://docs.couchdb.org/en/latest/install/unix.html#installation-using-the-apache-couchdb-convenience-binary-packages
mattpr
  • 471
The following commands worked perfectly on my Ubuntu 20.04. It should work for 18.04 too:
Enabling the Apache CouchDB package repository
sudo apt update && sudo apt install -y curl apt-transport-https gnupg
curl https://couchdb.apache.org/repo/keys.asc | gpg --dearmor | sudo tee /usr/share/keyrings/couchdb-archive-keyring.gpg >/dev/null 2>&1
source /etc/os-release
echo "deb [signed-by=/usr/share/keyrings/couchdb-archive-keyring.gpg] https://apache.jfrog.io/artifactory/couchdb-deb/ ${VERSION_CODENAME} main"
| sudo tee /etc/apt/sources.list.d/couchdb.list >/dev/null
Installing the Apache CouchDB packages
sudo apt update
sudo apt install -y couchdb
matigo
  • 24,752
  • 50
  • 79
Sach
